Or buy a KTM 950SE caliper mounting bracket.
About £52 IIRC.
After trudging through about 30 pages on XC front suspension on ADVrider, i came to the conclusion that if "improving" on the standard suspension, the best way forward were either 48mm WP's or the new 50mm closed cartridge marzocchis. while the 43mm WP's almost fit straight into the existing clamps, the consensus was they didn't have the spring rates available that the latter forks have.
But to stir things up further, a little digging revealed that kayaba's do a big fork as well (fitted to yamaha wr450 IIRC), and as i understand it, these are very tune-able, yet under-rated forks.
I was looking for kayaba's, but i found some near new 48mm WP's from an enduro R first, which being a bike of similar weight to the XC, ment they were likely to have original spring rates that might be close to those actually required, and also being local and from a trustworthy source made them a no brainer really.
I got hold of some secondhand ktm EXC yokes from a guy on the KTM forum, and got the local machine shop to turn the stem down so the XC bearings would fit. All in, it took me about 4 hours to swop the front ends yesterday. All that is left now is to make brackets to fit the speedo, headlight and ignition switch.
IIRC, The feedback on the original ADVrider thread about the 45mm shivers, were that they weren't as good an option as others available.
HTH
