META M357T Alarm
Ash
Oh Yes....
Earth
2003 1150GSA
Bike has been stood since Oct 2011,started regularly.
Went out today and all started well,turned ignition on,pressed key and " BEEP ".
Pressed starter and away we went,rode to Portland and then Yeovil.
Pulled in for fuel,went to start and no " BEEP " from key and no fuel pump noise.
kept trying for 40 mins and luckily she fired up,got home,switched off.
Went to restart and nothing again.
I have checked both 2 x 3 volt battery's in the key and key fob and both show over 6 volts,so they seem fine.
Any thoughts / causes.
Thank you in advance............:beerjug:
A strong local radio signal can mask the key code, can be a mobile phone aerial. Worth checking out you keycode that can be entered by switching on and off your ignition. Happened to me at the top of a peak in the peak district, did not know what it was until I looked up and saw I was parked under a 100 foot aerial.
:thumb
will try in the morning thank you :beerjug:
[ i was next to RNAS Yeovilton and and radio masts in a field ]
Contact Meta, via their website, who will give you the details of a local geezer to get in touch with. Invite him over to your place to diagnose the problem and after a short while agree to have him (or her) insert a short circuit link into your loom and confirm that the bike starts every time. It'll cost you about £35 if you are a time traveller and can get back to NW Kent in 2007.
Mine just went loopy, without notice, and was very annoying for a couple of days before the Geezer turned up. He just declared it as "useless" after a couple of "resets" and offered me the above solution.
Get rid of it and accept the anxiety. :comfort
i will try the code in the morning,but want it gone asap now.
Cant be doing with unreliable bikes,would get a 1200 again,if i wanted unreliability ;)
:kissy2
[ hope you are well and your GSA is now sorted ]
:eek
<a target='_blank' title='ImageShack - Image And Video Hosting' href='http://imageshack.us/photo/my-images/69/419604.jpg/'><img src='http://img69.imageshack.us/img69/6227/419604.jpg' border='0'/></a>
goodbye Meta
Oh my.... Has it all gone back together? And will it start?
Sunday for a porridge?
:eek
goodbye Meta
Yer need to change that airfilter. :augie
The Mobile phone masts up at the Ponderosa seem to stop some alarmed bikes too, I believe the breakdown services have cottoned on and now advise people to roll a way down the hill and try again before turning out.
glad you got it sorted Ash :thumb2
The thing is too scruffy for anyone to want to nick it anyway :augie
Meta hassle
Only time I ever had a problem with my V Strom was when rain totalled the fob on my Meta. Spare fob was at home - of course. That was game set and match for me up in the far north west corner of Scotland. Meta wanted about a million £ for a replacement and evidently it costs similar to have the alarm removed. Hope your problem is aerial/mast related. No alarm on the GS - no problem. If someone was to steal it then I hope it falls on them so I can LMAO
Going to take the alarm off Saturday. :eek
Just needed to check,that my plan was the correct way.
Thank you Jay ;)
i will post a picture report [ unless i feck up,then i will say nowt ] :augie
:thumb
That'll be it :thumb2
I had the same, somewhere in Poland I think, at some motorway services.
We were right next to a field with these bleedin' great aerials in.
I pushed it 100 yards down the road, coasted another 100 yards downhill sitting on bike and suddenly my pinger worked again :thumb
Yer berk you....should have checked here before you took the alarm off :blast :rob
Something blew the Main fuse and checking with 2 ex Alarm / BMW tech guys and this being the second time.
The Alarm had to go......
flyd i may be,but not darft :pullface
Thank you Jay ;)
I don't know what info you're working from but the Meta 357 on my RSV was removed and a single jumper wire was installed into the now empty connector to restore normal operations. :confused:
putting the wiring back as BMW made the loom
ie
taking out all Meta wiring ;)
Sounds like it wasn't properly installed then.
It's a Thatcham approved device, so it should have at LEAST twin circuit immobilisation to prevent Chavvy Scrote from doing something simple to bypass it.
<a target='_blank' title='ImageShack - Image And Video Hosting' href='http://imageshack.us/photo/my-images/201/419326.jpg/'><img src='http://img201.imageshack.us/img201/4082/419326.jpg' border='0'/></a>
:aidan
