Bob Southgate said:If you had said that about the 1150, I would agree with you, but I wouldn't describe the 1200 as weedy above 85mph.
ok bob weedy may be the wrong term but it aint strong thats for sure
two up with all the luggage it isnt exactly pulling up tree stumps it improved slightly with a full remus cos it cleared that glich just above 50thou
for a 1200 motor it could be a lot better ...yes if you hammer it in forth and fifth it will pull to a ton quite quicky .through the gears its well quick enough but it hasnt got the grunt in the higher gears you would expect from a 1200.....
i think its cos it revs only to 7500 and makes most of its power well before that about 6500 as felt through the seat could be wrong
or that 6th is a tad to tall ..lot better than the 1150 though
it is the way it make the power ie impressive lower down the saccrifice being higher up the gearbox but from 80 up in top fast it deffo aint
this is just my honest opinion
bear with me that firestorm engine 1000cc 20 percent less cubes
it pulls well low down not as well as the gs but there not alot in it but when you hit say 60 i top gear it just romps away with it
same hosepower about 100 ...making the pwer differently speading it outover a higher rev range and again pulling about tenty percent more weight .. they just seem to have the balance struck alittle better with the gearing and torque curve
it really is a peach of a engine which endears you more to disregard some of ithe bike other shortcomings
just dug up an old posting of mine so you can see it was bothering me before all the shit hit the fan some intresting responces as well
http://www.ukgser.com/forums/showthread.php?t=73775&highlight=missing+power
