Missing hole !
Risers came today and ive fitted them. But im not impressed TBH, there should be a hole in them to allow access for tightening the front clamp bolt but there isnt ! Anyone else buy these "made in britain" risers ? Please note the clamps are tight despite the gap in the o/s clamp front bolt.
Why don't you make dem a call? I'm sure they will send you a couple of holes in the mail. :aidan
Rox Risers come with Allen bolts that you can also tighten with a spanner. There’s probably a technical word for them, but I’m an oaf! See if you can get some of those.
Cap head screws is the correct name if fully threaded or cap head bolts if there is a proportion that is plain (not threaded). For this application you would probably specify Grade 8.8 as it likely requires a relatively high torque value.
can you do the rears first then pull the bars back into place and nip on the fronts?
