More Garmin 2610 help needed !
CJ.
Dorset / Andalucia
Hi guys,
I'm sure someone out there will be able to provide me with a simple answer to this, i've searched the forum but found nothing conclusive. Is it possible to connect a bluetooth dongle to the Garmin 2610 to allow wireless communication with a scala rider Q2 headset ?
Cheers,
Chris.
Hi Chris,
no !
You may route the 2610 audio signal through a communication system with BT, but I don't know any suitable.
Regards
Dietmar
Hi Dietmar,
Thanks for the info, think i'll go the hard wired route !
Regards, Chris
You could possibly use something like this.
Try doing a Google search for 'bt dongle 3.5mm', this should bring back plenty of opportunities.
You'd need to use a 2.5 to 3.5mm adpator to plug into the audio out on your Garmin motorcycle lead.
Cheers Bumpkin,
That looks a possibility ! i'll just need to confirm that the Scala Q2 is backward compatible with BT 1.2.
Regards, Chris.
Thanks again Bumpkin,
Have emailed them for cost and shipping info.
Regards, Chris.
