casperfelix
I know this subject has been covered a lot - but just thought I'd say: fixed my tobinators on my standard screen 1150GS (15min max); set them up as suggested in the blurb that comes with them; rode with this setting for a couple of days to get used to the difference - which was considerable - and then did the 'adjust with your left hand as you ride' method of finding the sweet spot.
It worked, and I echo the comment made by someone else that setting the screen so the wind hits the top of your helmet is the perfect place.
I'm 5.11 and found the front fitting set at about 80% max extension and about 30 degrees off the vertical towards the rear was good. Then ride and adjust the rear fixing to the get the air flow just so.
Brilliant bit of kit, looks neat, reduces the buffeting but leaves you feeling your on a bike.
PS It reduces airflow noise - but there is still plenty.
