Motobatt battery
Big E
Manchester
Just fitted a brand new Motobatt battery out of the box to my GSA, put everything back, tried to start the bike and nothing? It tried but failed to fire up ?
Do these batteries need charging or should they come good to go out of the box ?
Thanks.
take it back off the bike,charge it on a battery charger then refit it.it could have been stood a while on the shelf before you got it .but generally a new battery should be almost fully charged and ready to fit
You’re a bit vague in the description of your problem - I assume the engine turns over but doesn’t start ? If so it’s almost certainly the throttle cable dislodged from it’s holder, usually L/H side. Someone will post a picture , of look in the section sticky, Tips and info, where this very common problem has a thread of it’s own. HERE
Turns out to be a knackered starter motor ��
