Motobatt
Delboy777
In a Remote area apparently.
Hopefully this will kick my tractor into life :D
Good choice :thumb2
I'll be wanting one in a month or so, where did you buy yours?
(Mine will be the MB51814 for a 1200RT)
Why are you charging it .:blast
On the front it says "no initial charging required, install and go "
Oddly enough, yes!
Plus it stops you getting LAMPF errors with HiDs most of the time. Occasionally I'll still get that on re-start if I've filled up with the phone charging and the Satnav still powered through the loom.
But far better than the original battery though.
Anyone know if these fit the 20100on DOHC too ? The application chart only lists it to 2009.
Now sure whether the SOHC & DOHC take the same battery.
Are there any different connectors needed, or does the Motobatt fit straight on ?
John
Yes they fit twincam bikes. No alteration needed to cables.
But as the battery casing is smaller than OE, if you make up a plastic or wooden spacer the original band clamp keeps everything in place correctly.
PM me if you want the sizes.
£47.80 From Amazon. Stuck it straight on the bike and fired it up no problem. On a cold morning it sounded like it was turning the lump over a bit quicker than the original did on a warm day. Only time will tell if it outlives the original. It lasted 5 years and still never let me down. It was getting a bit slow cranking and the optimate says it is past it's best.
Good choice :thumb2
Is this bigger capacity than GSA battery? If so I would like the extra capacity but will it fit the GSA?
I got a bottom plate with my one, is this not enough ?
I preferred to fit it by putting it on the base and making a small spacer to fit under the original strap retainer.
Two thin strips fit inside the 'step' of the original retainer:
