There were 2 guys working on the bike in stages.
A recipe for feck ups.
Just had a major service which transformed the 1200GS no end, I rode home on a totally different bike and was a happy bunny. Just been out on it today and its like a bag of spanners, rattley and harsh, like the timing is advanced. Anyone help out here?
So, was your bike transformed or not after the service?My return home was not a vast distance, the oil level was checked as a matter of course the next day when the symptoms manifested itself. Please give me some credit here guys & gals. I can state quite categorically that the machine had oil in it when returned to me after the service, it didn't burn or leak oil on the return journey. Why would I drain 60 miles old new oil and run my bike? An enigma indeed?
The rest of the motor is perfectHas Mikeyboy checked the oil pump and oil pressure relief valve yet? Oil pump rotors free to turn and not worn/scored?? Oil pump drive chain not broken. Oil pump pickup not blocked ?? Anything blocking the (new) oil filter ?? Anything else found ??
If the bike seemed to run okay between the dealers and your home, and had a normal oil level in the sump then perhaps the damage was done on the ride home but you just didn't hear it at idle before turning off, then the mornings restart without earplugs revealed all ??
I presume that the rebuilt engine will have an oil pressure gauge attached during its first start up ??
knows and he won't cough to it. Shame, difficult to prove and the owner picks up the bill.Back in my power industry days we had a large Cummins started without oil. It was the front engine on a Terex earth scraper, the driver realised there was a problem so shut it down immediately. We filled the sump and it seemed ok but within a few hours running time the bottom end was knocking. White metal bearings pick up without oil and then fail fully over a short period afterwards.
The workshop cockup theory makes sense but proving it is another task altogether.
If all the options for oil starvation after you took the bike home have been exhausted, then no matter how difficult it is that you can prove the point, I still think you should get back to the blokes that did the service and let them know what probably happened.
At worst it won't change a thing however you have probably lost trust and will already be reconsidering getting your bikes serviced elsewhere. But at best it will make them realise that there's a problem with their processes and it might save another bloke the same grief you have gone through.
