Mystery C Clip
Ajay
North Yorkshire
Anyone recognize this. 9mm across jaws, so a 10mm bolt retaining clip?
Found on garage floor. I own R1150RS & R1200GSLC
Browsed RealOEM.com, can't identify this part
Front brake
Sent from my G3121 using Tapatalk
My guess is rear brake pads retaining pin goes on the end of the pin as it protrudes out of the caliper ?
Thanks for the suggestions guys & to beemer pimp for troubling to take a photo
Now resolved - Embarrassingly its not a bike part at all, its from a garage door spindle!
Its just a retaining circlip,
multiple uses, accross many factors, not a bike specific item.
They are normally pretty robust, and need quite a bit of force to remove,
they dont normally fall off through wear though. , or get levered off by the part there fitted to wearing / moving and forcing the clip off
usually not fitted properly and the ping off after time.
Nothing to do with brake rotors afaik.
pad retaining pins are R clips, and the rotors are bolted / screwed in
Maybe it's different size but this from front brake rotor on 1100 rt cast wheel
