I’ve owned and used a Nav V, Nav VI, Garmin XT and currently running a Connectedride Nav. As with many tech items, the two BMW nav’s and the Garmin XT, have a host of features I would never use, but you have them should you wish to.
The Nav V and Nav VI were both great at navigating, but I hated the Garmin XT routing.
Even if bespoke routes were made and uploaded from MRA, the XT would quite often change it. I did find out by chance when on my last tour with it, that if you changed the MRA waypoints from tear drops to hand symbols, that it would route via each waypoint.
The thing I like about the Connectedride Nav, is its simplicity. It doesn’t have any fancy apps, which I would never use and the mapping (Tom Tom) is really clear and uncluttered.
When used in conjunction with the BMW Connected app, bespoke routes can be easily created (I find much easier than using MRA), and when sync’d, are exactly the same as when they are created in the app. It is also easy to create routes on the device itself.
As a quick memory dump, items to consider with the Connectedride Nav -
It will work as a standalone basic nav, regardless of if it is connected to a mobile phone or has its own SIM card installed.
It requires sight of the cloud to sync data and routes with the phone app. This can be achieved by Wi-Fi hotspot with your phone, or by fitting a SIM card. Whichever you chose, it still needs mobile coverage to complete the sync.
It requires mobile data, via one of the above methods, to get live traffic information.
When the bike shuts down and the nav is left in the cradle, it only goes to sleep. Just like the earlier BMW nav’s, it has to be removed from the cradle to power it down completely.
It has a really clear screen, which can be seen in all light conditions.
It has a really quick processor, and calculates routes far faster than any other nav I’ve used.
It has no setting to turn off “auto recalculate route” if you wander off it. I thought this was going to be an issue, but never really noticed it when away on my last tour. The ease of adding waypoints in the app, and the ability to easily skip the next waypoint when on the move, made any detours stress free.
Searching for a location or destination is easier than any of the other nav’s I’ve used and letting the nav do the routing for you is easy, and you have the normal choices of fast, winding, direct etc, as well as the ability to avoid the likes of tolls, motorways, unsaved roads, etc. For me, the auto routing is better than the Garmin XT.
Bluetooth connection to my iPhone and Sena SRL2 has been flawless and the call and music streaming quality and been perfect. However, Wi-Fi hotspot connection can be a bit hit and miss (I’m sure this is an iPhone issue, not the nav’s), but with the aid of iPhone automation set up, Wi-Fi hotspot works 100% of the time for me.
It has the option to load maps of the whole world, or just the areas you want.
It integrates with the bike and shows a full list of engine and operating data.
It doesn’t show gps speed.
BMW recommend you leave out all phone and headset connections with the bikes TFT and just connect to the nav. If you always ride with the Connectedride on the bike, this is not an issue.
BMW have taken a lot of flack over the Connectedride Nav, but with the recent software updates, the unit is getting better with each update.
