Need panniers, what to get
ymfb
Salisbury
I have a 2011 F800GS and want some panniers for commuting and blood running. I have no plans for world travelling so metal is overkill. Ideally something narrow, top opening.
I saw something on a police spec RT that would do.
Please make recommendations
Not sure if Givi stiil make them, but have a look for Givi E21 side cases, they are plastic with a top opening lid. They are also narrow & if i recall, quite cheap! Good luck.
I was looking at the E21 cases, cheap and top loading...
I found a cheap set of SW Motech Trax boxes... never looked back. Packed loads into them, does make the bike pretty wide though.
I have the SW Motech frames and Peli-Storm cases.they are not top loading but are very tough and waterproof.I believe Peli do a top loading case but you would need to check dimensions.
They are not as wide as this picture suggests,in fact they are only about 1" wider than the bars.
What size are the Peli cases ? Are they really pelican ?
i'd have a chat to rodger at ardcases sure he can make what you need, very happy with mine
I bought a couple of 20mm Ammo cases recently from army surplus store.... 15.00 quid each.... bargain & bulletproof! :thumb
you said no metal..... I presume due to cost.... but these are super-cheap!
(not mine in the pic - but same boxes)
The Peli Storm cases are IM2400 and IM2450.The narrower one(2400)going on the exhaust side,this gives a more balanced look.The cases came from
http://www.galeforcecases.co.uk/
The fitting kit came from Caribou cases in the USA and an excellent piece of kit it is as well.
Just bought a 2011 800 30th Aniversary Model, loving it so far. I plan to fitt the Givi Trekker Panniers and possibly Top Box. Are their moounts available that will allow me to fit a Peli as a top box on Monokey Mount?
Roger from ARD cases fitted these in May. They worked a treat for the trip to the IOM TT. Chuffed to bits with them.
Yep, that's my bike in the photo, cheap boxes if a little heavy (I don't carry a pillion so no prob there). I fitted the boxes to a Givi rack. Just done a European trip with them, very happy, and they were cheap too.
I looked at Varios at my local Motorad dealer and they are just too big and too expensive.
