Thanks. But that I get...
What I don't get is the comment saying nitrogen exists in its elemental form in air.
My question then, perhaps put differently, is before the oxygen has reacted with something, what form is it in, if not its elemental form? Presumably, before it has been used by us to breathe or it has rusted something, it's floating around in its elemental state also?
I will try and explain.
Firstly - elements refer to the single ‘element’. Such as Hydrogen (H) , Helium (He). etc.
Each element has a series of electrons and excluding the transition metals, these electrons consecutively fill a series of shells, starting from the inner shell and work outwards.
To be stable the shells must be completely full.
The noble gases have these complete shells and hence do not want to lose or gain another electron. This is why they are regarded as inert.
The closer the element is to filling a shell the more reactive it is e.g chlorine and Hydrogen.
The filling of these shell can either be filled by donating/accepting an electron or by sharing.
Nitrogen need to acquire three electrons or lose five electrons to have a complete outer shell - this is difficult- it is easier to gain three. However so much energy is required that it shares these with another nitrogen atom.
Hence nitrogen exists in the atmosphere as N2
Similar with Oxygen but in this case it requires two electrons to complete the outer shell. So Oxygen exists in the atmosphere as O2.
When oxygen reacts with another element this initial bond has to be broken (requires energy), sometimes by heat, sometimes by the attractive force of another element but this energy requirement can be reduced by the use of a catalyst.
An example of a catalyst is in the motor car where, without it, the temperature required to breakdown the pollutants would need to be much higher
