Non Standard Size Sprockets:
Cuprinol Man
Hull, East Yorkshire
Hi Tossers.
Anybody know where I can get different size sprockets from standard from?
I have tried my local m/c dealer but with no success.
Sprocket size change
HI
I have changed mine front up to a 17 to spread the distance between the gears so that I am not short shifting (skipping ratios) when changing gears. It has given the bike a nice relaxed feel and does not effect first gear ratio much. I think my front sprocket if off an Aprilla. I also think the F660 GS Twin has a different front sprocket size. so you could try this. A good bike shop should be able to help.
Which way do you want to go ? higher ot lower gearing.
Rob T
