Odyssey Battery
Reckless
Oakham, Rutland
Anyone fitted an Odyssey to their GSA LC? My stock battery failed recently and I fancy a more reliable replacement.
Pete
I'm interested in this from a standard LC perspective too.
Once you've had an Odyssey, you never go back :).
Not true.
I had one, then my next battery was a Motobatt......every bit as reliable, smaller (or higher powered for the same size) and significantly cheaper, plus a better design (twin poles for each terminal)
Example.....
MOTOBATT for 2011 GS, £51.99 delivered
Odysseybattery, same application, cheapest I can see on Ebay £85.45
Possibly true :augie.
I have a Motobatt on the Trumpet and it's gone thru the first winter without any issues. I'd like to see it get thru another 1 or 2 unattended before I give it the same praise. So far it's been 100% and easy to use, particularly liking the multiple connectors. I convinced a friend to try it in their Gixer too and he's been happy so far, apart from finding when delivered it doesn't include as standard the screw and nut to use the additional terminals. TBH, if you're removing an old battery that shouldn't be a problem.
I had the trumpet serviced by a good Indy last weekend and he was critical of it, but that might be more of someone who only likes OEM in which case Odyssey might have got the same response.
Does anyone know the Odyssey Battery equivalent model number I need for my R1200GS LC? - Battery has started acting the goat and I would like to know the odyssey part number I need.
I just ordered one from eBay - item number 360974396686 if anyone wants a good deal. Last few remaining
