It is a 10 minute job
Work the profane in to loosen all the grime....
I'd swear it's easier to use chain cleaner.
A paintbrush some paraffin and a rag !
Work the profane in to loosen all the grime and then with rag in hand round the chain just spin the wheel until its clean and shiny then apply fresh lube !
every 300 mile or so
as said i find it therapeutic and it really is an easy job
I might give that a go for fun, ta
Won't the solvent get past the O-rings and into the stash of grease in the roller that the O-ring is supposed to be protecting though?
Andres
Eventually yes but if you think about it anything that shifts the crap off the chain will have some sort of sovent in it and by the time parafin has done what you suggest the chain will be fecked anyway from use.
Many manufacterers recomend parafin as the cleaner of choice and as wapping points out there are specialist chain cleaners available at a price !
My logic says that a clean chain will last longer than a dirty un maintained one
I thought that the idea was that the metal side plates no longer rub against each other so the dirt didn't matter![]()
I cleaned mine last night, I hadn't realised it was gold
I do reckon though that it'd be cheaper to treat chains as disposable; £10 on a can of chain cleaner (nearly all gone), £12 on posh 'dry' lube and fecking ages spent cleaning the 'dry' lube off the rest of the bike 'cos there was no way of regulating the amount the can chucked out......
I think I may just go back to my usual regular application of a small amount of normal lube and the occasional wipe with a rag........
Andres
Bloody hel;l Chain cleaner at £10 ...I cleaned mine last night, I hadn't realised it was gold
Andres
Did you use Paraffin, or normal chain cleaner? We need pictures!![]()
................... as for dry lube I am not a big fan as I believe it does not work well if it rains
Chain cleaner this time but I think I'll use paraffin in the future as I used up a whole can (mind you it had a hell of a job to do!) - PicturesI'll pop out later and take one just for you but be warned, it's not up to Nutty standards, I was content just to see my black chain become a vaguely gold chain
Andres
That's been my experience in the past too which is why I usually use just a good quality 'normal' chain lube, a little and often..............just thought I'd try a different brand and see (Silkolene Titanium Dri Gel).
God, I can't believe I've somehow got involved in a thread about chain lubes![]()
Andres
PJ1 Blue label is my fave !
Andres
Can you still buy parafin?
Feck ......chain cleaning with parafin is going back to the dark ages
Have you not seen these bikes with shaft drive yet, they're the future
I hate chains (even though I have bikes with them)
