Oil leak ???
younger06
Naas, Ireland
I noticed the area inside the beak of my 07 GSA (on the right hand side) including the oil pipe coming from the cooler and the top section of the fork are covered in what looks like oil (not dripping but smeared) Do the pipes/hoses/connectors at the cooler give trouble, or the cooler itself???
Doesn't seem to be much coming up on a search, I was wondering is this another case of ....."they all do that"
Hoses occasionally, if it is them you're far cheaper going to a hydraulic specialist, like Pirtek. They made ones for my Trophy, no longer available from Triumph, with different ends to fit a far cheaper aftermarket oil cooler.
It is more likely to be the cooler, caused by either damage or corrosion.
Sent from my SM-G925F using Tapatalk
Sent from a U11
