jimish
Appears to be coming from 6 o'clock in the bevel drive housing.
Has anybody changed the gasket PN 33 11 1 242 788 under the cover?
Is it an easy job?
Looks like there's just 8 bolts holding the cover on. Haynes manual says take it to a dealer!! but it does give a torque figure for the bolts. I think I will just check the torque loading on the bolts first.
it's only started leaking since I topped up the oil in the drive shaft so I'm also wondering if the oil seal twixt shaft and bevel drive has gone. Thinks : check oil level in shaft, if it's gone down then the seal has gone and that's going to be a bigger job.
All suggestions welcome guys.
Is it an easy job?
