jack.pe
Hi Guys,
I have a 1200 GS, 2004 year and I have just found a buyer.
Today I took the bike out and the warning light for oil came on, I topped up the oil, restarted and it went out. I have checked and the level is definitely fine through the siteglass and measured as per the manual but the oil warning light has now come on again. It seems that when first started it comes on and will stay on (even for 20 minutes riding) but if I switch the bike off and restart a couple of times eventually the oil light goes off and stays off.. I assume the oil pressure sensor must be faulty?? any ideas? if it is the sensor is it easy to change?
Obviously I won't hand it over to the new buyer till the problem is fixed but just worried if it might be bigger than jsut the sensor??
