Paralever needle bearings
Green Boy
hampshire
Hi all,
Fairly sure I know the answer that I'm going to get here but don't suppose anyone has ever found a non OEM bearing which fits before I spank best part of £80 on the two...
I've seen suggestions that there is another option ie. from Rubber Chicken but don't fancy having to get them shipped from the good ol' US of A as it would appear that it's going to be the same price.
Also can anyone recommend where to purchase a torque wrench capable of 160Nm as mine only goes to about 120Nm. Failing that has anyone got one in the Southampton/ South Hants area who wouldn't mind lending it to me in return for beer??
:jager
Nope No other spurious make in that size BMW copyrighted or patented the dimensions or something like that
There is a 16mm wide one I found but then lost interest is locating 1mm shims the right dimensions to take up the missing 1mm
Hi all,
:jager
I'm in Southampton - Fair Oak/Eastleigh way. You can come to mine and change them if you like. I've got an F Off wrench - I presume for changing the little buggers, or you can borrow it
I've also got solid paralever bearings - rubber chick 'like' but from (Polish?) Dan of this site who makes them.
