Pillion seat cover plate
The removable version
Thats the one from Motorrad Bohling i have available for £45, plus post,
after a voyage of discovery with delboy we are certain it won't work with the sw motech bracing bracket for the top box,
fits all non modified wc gs/gsa bikes, with or without grab rails, can't use it to mount top box with grab rails,
Photos in post 7,
Nice quick release modification Job, Stick,
Slicks conversion looks ace
Thats what it should be like
Practical and easy to remove :)
30 MINS. Straight forward.
It comes in bits,you have to build it first. That said, Once its put together, you could take it off or on the bike in 15. Its solid. Nice cubby hole for gloves, disc lock ect.
https://www.bmw-motorrad-bohling.co...50-k51-r1250gs-k50-r1250gs-adventure-k51.html
Home made version 2 seconds with the key , and further 10 seconds to refit the seat , tripping over said cans ….wondering where the cover was , and another 10 secs to refit .. works for me .
Photos in post 7,
Thanks , appreciate the kind words , I can convert the bike to so many different looks as all removable , call me vain but I like a change
I can't imagine any situation where its necessary for fast transition ?
Handy. But not essential.
But less screws fixings and other fiddly stuff to loose or bugger up in the process ;)
I like it a lot :)
I like it a lot :)
The downside, for me, would be that it doesn't allow access to the full storage space, such as it is, under the rear platform. I guess it would be possible to cut a hole in the bottom of the pillion seat base which stick used to create the fixing. However, that would mean that the compartment wouldn't be well sealed against the weather. I'm also not sure about the mechanical security of a Vario top box mounted on a removable plate.
On balance, I prefer my standard factory method of bolting the luggage platform down as I don't plan on carrying a pillion passenger.
Agree with the top box bit and the security but I don’t use it like that and to be honest it’s more for looks , full access to the under seat area tho and also the storage in the unit itself . It’s the on and off I was after .
For me yes as I don’t like the rear seat on as it does not make me happy with the looks , if wife wishes to go out it’s a 10 second change to fit the seat , thus gives me the options , and back again after , no messing about . It’s also a great platform for the luggage I use when away solo (35 ltr roll bag and mini box for the computer water proofs etc )
