Ping!
GerryC
Kerry Ireland
Was lucky to get back from Wexford last Sunday when the occasional pinging sound turned to a more ominous sound.
The story has its roots the day after Paddy's day - when incidentally the bike got buried in a bog hole up to the front axle. The following day in Donegal I went off alone & occasionally heard a pinging noise which had no apparent cause. Eventually I persuaded myself it was gravel hopping off the mudguard.
The noise went away & I went home; cleaning the bike revealed slight play in the front wheel. Tightening the axle slightly addressed this & the wheel ran smoothly with no tight spots or no apparent roughness so off to Wexford sets I. All ran smoothly till approaching Newsastlewest coming home – the pinging returned; by Abbeyfeale if became a gentle but intermittent grinding noise. Stopping revealed no front wheel play; coasting did not throw any more light on the source of the intermittent noise, As I approached Tralee an intermittent vibration in the handle bars became apparent; I backed off the pace a little & got home.
Detailed examination did now reveal roughness in the front wheel – removing the axel resulted in a handful of loose chipped balls. The wheel bearing had failed but had survived close to 1.000 kilometres since the noise first heard in Donegal.
I replaced them today but was lucky to get so far on the old ones or stupid for not spotting what was happening earlier, Gravel it was not & tightening up the front axle a smidgen was not a great move – lucky lucky boy. As they say “the wheel turns” but ...............................
Balls of steel
What mileage is on them bearings Gerry? And the enevitable question, did you ever power wash her?
Tom.
Tom.
106,000 Kilometers & very occasionally powerwashed.
Still an early failure but easily sorted once home.
