play in sidestand
panic_revs
Essex
Hi All
New to these bikes ... I've read the sidestands have a bit of play in them but my bike seems excessive! Can anyone confirm this needs a rebush? Is it possible to shim them?
<iframe width="420" height="315" src="https://www.youtube.com/embed/d81k1p-rc5Y" frameborder="0" allowfullscreen></iframe>
I replaced the side stand bushings in mine a few years back, it made hardly any difference.
Shim washers to pack the space between form and mounting will reduce slack better than the central bush.
If you need a height extension the machined poly type are light and don't increase vibration forces like a solid rubber hockey puck. If it becomes a bit stiff moving, you might need an extended cap screw to catch with your boot sole.
(some Japanese bikes have a ball ended peg to do the same job)
