Poor attention to detail.
Meh, you guys forget the special touches:
Plugs look good, but for dog's sake paint the frame behind the plastics!
Jim :cool:
Funny thread! But … sadly … I thought much the same … and I am sad enough (and rich enough just now) to think of buying plugs … the posh ones look nice :cool:
Is that all bollocks then that if you put the bungs in condensation builds up behind them and causes corrosion!
...to stop water becoming trapped. Saying that, if I designed them I'd include a few small drain holes then add the end caps
Properly designed end caps could allow the pipe to drain. Depending on the end cap you get from your home center it will not be an issue.
Jim :cool:
All Bunged up !!
Fit what you want, you are a grown up
Before I looked on here and saw the nice bungs I didn't realise they were made for the Bikes so,I decided to bung me oles on the (very ) cheap !! :D:D
As wine bottles etc have Corks,I thought yep,corks will do.
Bag of mixed sizes off ebay,£2.99 some sizes fit,others too big so obviously not used ;)
Depth cut to suit,ends coloured with permanent marker,job done.:thumb2
Easily removed if need be and easily replaced.
Might have to get some posh ones now though :blast
