Popped My Tyre Changing Cherry!
Dazlove
Southampton
Fellow Tossers
Just a note to say if anyone out there is apprehensive about changing their own tyres then don't be.
My rear tyre was looking a bit bald (probably in sympathy with its owner!) so thought about replacing it. I happen to ride by a well known dealer most days so usually stop there for a quick tyre change, but looking through my receipts I was becoming uncomfortable at having to pay over £90 just for labour to replace both front and rear tyres.
I know I would have probably found another tyre fitter to do it cheaper if I had looked about, but I decide to do a bit of research and do the job myself.
Yesterday I fitted a new Tourance to the GS and this morning covered 70 miles to work and all is well.
The kit I bought was Abba bead breaker, 2 x 450mm tyre levers, Tub of tyre lube (13kg......should last a while!), new valves, valve core remover, valve installer and 2 x rim protectors. The rim protectors are pants for the GS rims, as they are too small, so after looking a a couple of YouTube videos used an oblong of plastic from a plastic bottle. I also already have a small compressor.
I nervously tackled the job, but it was simple. I had left the new tyre in the sun for a while to warm up and it really was no effort to install.
As for balancing, and I know this is a contentious issue, I decided to go the Dynabeads route. It was a simple case once the tyre was on and inflated onto the rims, then I removed the valve core and put in the required packet of beads. These should be reusable so should not be a recurring cost.
To summarise, I bought a pair of Tourances plus all of the tools to change them for less than it cost me to have the tyres replaced at the dealer and I still have all of the tools for future use.
If you are thinking of doing your own tyres, give it a go, I really was surprised how easy it was.
Regards
Dazlove
If you pop the rim protectors into a bowl of boiling water for a few minutes they soften enough to stretch over the GS rims. One or two treatments will leave them re-shaped to fit.
Rim Protectors
Thanks MikeP
Doh! Didn't even think about that.
Good Tip.
Regards
Dazlove
I normally go to Micheldever tyres and I think they are about £30 to fit two tyres from memory. They also keep virtually all tyres in stock and have done a complete change in about 20 mins. You can get it much cheaper if you just take the loose wheels in. £90 seems very steep but I think I know where you mean!
£90 for fitting two tyres is a rip-off even if it's a ride in/ride out service. I just paid £79 for a front Tourance including fitting, valve and balance. At the same time they fitted a rear Tourance that I supplied and fitting/valve/balance for that was £15.
That's to loose rims, admittedly, but I prefer to remove/re-fit the wheels myself.
Nice work. I've been thinking about doing that myself. I used to fit motocross tyres and it was a real nightmare but they are super tight on the rims as they run such low pressures. A VFR I had, had the rim scratched by a tyre fitter. You can be super careful yourself.
Ravings of an old fart (many tyre changes does this!)
Don't for get use a dustbin as a bench for tyre fitting, works wonders.
