power lead for mobile phone
Alpha
Newcastle
I have an 05 GS and would like to run a power lead to a waterproof case in which ill hold my mobile phone. the battery on the phone is pants so i need a form of power that is compatible with a mini USB plug that the charger usually goes into
Any ideas?
Can i link off the power suply under the beak (which i still havent found btw). im assuming this is 12v and the usb is usually 5 ish? Again any suggestions welcome
ta
Dave
I have a canbus plug wired to a regular cigarette lighter socket, which leads to a regular car USB charger and my iPhone. This little lot lives in an old Walkman case that loops around whatever the bungees are holding down onto the back seat. OK, not waterproof, but then I only need it for an hour a day. The plus points are that its simple and can power other 12V stuff too.
Google Powerlet:thumb2
As Toad mentions, Powerlet is in the equipment and toys section, or go to www.locatis.eu
im assuming this is 12v and the usb is usually 5 ish ? that's dangerous and as you do *not* mention make model of phone then cannot be exacting. If Nokia then you're b*ll*x by this assumption as the trigger voltage is greater than 5V.
