PowerCommander III 800 GS
ZZ10
Stockholm Sweden
will PC III fix the stalling issue and give better performance?
http://www.powercommander.com/power...ander_all_downloads.aspx?mk=3&mdl=213&yr=2008
The BMW CIP 12 software update will fix the stalling issue. The PCIII may give better performance.
thanks, when was CIP 12 released?
will PC III mess up the fuel computer etc.?
CIP 12 is out in the US and UK. Check with your dealer about availability in your country.
I'd suggest contacting contacting DynoJet direct on the second one. Generally, if you have to ask that question, the answer is probably. :D
http://www.powercommander.com/powercommander_iii_usb/powercommander_contact_us.aspx
Yeah i am a little lost with this thread. I know the power commander, but a quick definition of both would help.
If anyone else does not admit it, I will state that i dont fully understand this thread.
The GT1 BMW machine gets regular updates from the factory that contains the firware updates for all motorcycles. These updates are bundeled into release packages called CIP's. (think MacOS 8, 9, 10, etc.) Each release is accompnied by release notes that detail the update to each motorcycle containined within the package.
CIP 12 was just released. It's superceeded 11 or 11.1 or something. :)
Thanks, that clarifies this a bit. Do you know the release date of the new "service pack"?
I saw in one of those GS911 thingy that my bikes software is dated June 2008 but I was to lazy to write down the version number. Good to know that one can keep track of what is the current release of the software.
Hmm ... I have the GS911 device and I can't seem to get to the CIP level anywhere, or at least anything recognizable as such. Which value should I be checking?
Dump from the various systems:
Engine:
BMS-K
Part No.:7714466
Hardware Index:10
Coding Index:2
Manufacturer:Bosch
Manufacturing Date:2008-06-17
MCV:0.6.0
FSV:0.77.34
OSV:2.3.1
Program status:340I
Date release:GF10
VIN:WB10229019ZU00129
ABS:
ABS8M
Part No.:07711210
HW Version No.:1
Coding Index:0
Manufacturing Date:2007-01-15
Manufacturer:Bosch
MCV:0.5.9
FSV:3.1.0
OSV:3.4.32
VIN:ZU00129
Variant:K72 800 cc
Central electronics:
ZFE
Part No.:7718033
Hardware Index:C7
Coding Index:9
Manufacturer:Loewe
Manufacturing Date:2004-03-01
MCV:0.6.0
FSV:2.1.1
OSV:3.3.0
Dash:
KOMBI7x
Part No.:07701477
Hardware Index:C3
Coding Index:1
Manufacturer:Preh
Manufacturing Date:2008-06-30
MCV:0.6.0
FSV:2.1.0
OSV:3.3.30
VIN:ZU00129
Assembly No.:07701480
Nevermind, found it on the GS-911 Google group. Looks like the CIP number is basically the version number of the installer CD the shop uses to flash new firmware onto various ECU models. The disc itself has gobs of different versions of firmware, so it isn't immediately obvious to even the shop which version got installed, only that if the latest CIP gets used, the latest firmware should get installed. Poo.
Sorry, now, back on topic ...
