Cable tie method seems a bit bodge it and leg it fix I was looking for something a little more refined gents![]()
Having large hands, I found the clip to the rubber grip unsuitable, so asked Intaride for a PTT I could panel mount.
Got some nylon sheet and made this up.
No painting and no corrosion, probably would get a pure black next time but it was an off cut and took 15 mins to make.
It's a simple switch, which invariably fails at some point or other. The cable tie method to the handgrip is the most practicable, trust me.
Failing that, Google is your best bet. Loads of ways out there, often on US sites, including bods who have made all sorts of ingenious PTT switches. Worth the effort? Um..... No.
The first version did come close to the tank on full lock, so moved it up, the back of the switch is as high as it can go, but taking into consideration the need to be able to get a thumb on it with ease.Very Neat..it does not catch the Tank on full lock being low down ?
TWeedy, what kind of system are you connecting it to?
I have an Intaride Hawk system, and they are very helpful with various PTT buttons to suit, if you can get a panel mount version, you can make this kind of bracket, if it's an autocom style you may need to make an angled or machined bracket.
