On a connected subject.
I had to replace the fuel pump and level sensor unit on the 99T 1150GS because the green wire to the pump had overheated and snapped. I was using a work around with a pair of spade connectors but wanted to tidy it up. (stupid man)
Before putting it all together I bridged the male and female connectors with wires so that I could test the new pump and level sensor. I must have done something wrong as the 10A fuse for fuel pump relay popped.
I replaced the fuse, but still no pump. The level sensor is OK
Picture is worth a thousand words but I don't have a picture to show at present.
12V is present at the fuse. the supply through the ignition switch and kill switch seems Ok, so it looks as though the Motronics unit is not enabling the relay. Have I destroyed the Motronics unit? or is there another reason there is no 12v at the connector to the pump?
The new one has been sitting dry for a year. Is it safe to run either of the pumps dry, to test them? Can I put water in them rather than petrol?
