Question........
Bilks
Philippines...
:confused:
Dear Tech dept,
please, would anyone out there explain to me the benifits of upside down forks?
Also, reasons for a larger diameter front wheel?
I thank u,
Bilko.( Part 1 CBT soon !):D
Bilko
USD forks are larger diameter than conventional forks and therefore flex less,thus being more stable giving better handling.
unsprung weight
in upside down forks the normally heavy fork bottoms are now at the top and no longer directly connected to the wheel. The spring + damper mechanism can now work with more efficiency because of less weight driving the spring.
Larger Front Wheel
This can assist when off roading, it's easier to clear obstacles with a bigger wheel.
CC:cool:
Here Goes...
USD forks aren't (theoretically) any bigger diameter than RWUs... it's just that USDs are generally on big bikes, so appear bigger.
90% of their use is pose value, the rest is down to USDs being able to handle heavy forces better (don't ask me why, I'm no engineer)
A bigger front wheel has 2 advantages...
1. It's bigger, so handles bumps better
2. It's bigger (again) so has a higher gyroscopic effect, making the bike more stable.
HTH :)
Re: unsprung weight
Yep, I agree it is all down to reducing the unsprung weight.
Tim
