R100gs 1995 Fork Seals
barny
Tractor Central, Norfolk
The bike has been standing for about 6 months and I've just noticed the left fork is leaking from the top dust seal when compressed. I've had the bike about 8yrs and AFAIK these are probably original or old fork seals so probably worn or hardened by now, so question is... If I remove the leg can I just slide out the stanchion once the bottom bolt is removed to get to the seals and dust seal or will I need to dismantle the whole fork leg? The operation is fine and no play in the bushes just the leak to sort out.
Hi .. do you mean the very top dust seal, just above the top yoke? .. if so, I had a similar issue with small oil weeps .. I took off the dust cap, carefully unscrewed the topmost bolt ( the big 32mm hex - it has a spring underneath) and then just put two wraps of plumber's tape (PTFE) around the topmost threads of this top bolt .. this avoids any PTFE getting into the suspension leg itself .. bolted it all back down and it's now fine until I get round to rebuilding the forks later this year
No its the top of the lower fork leg, the dust seal is just that it's the seal under neath that's leaking.
Thanks Mike I've been through the Haynes Manual and its a complete strip down so you have confirmed my thoughts. I'll try both warming and slide hammer approach.
Might be as well to do a full strip down and clean out, replacing the seals and bushes as needed. It’s not a difficult job compared to modern forks.
