R100GS favour required...
barak666
Northampton
I'm looking for some info....I need to know the size of the stem nut/top yoke nut on the R100GS. If someone could measure the nut across the points of the nut - this is the diameter of the nut at its widest point and let me know the size I'd be very grateful.
Thanks in anticipation.
Hi Barak - I've just measured the nut on my 1990 R100GS and it appears to be exactly 2 cm across the points. In fact somewhat smaller than I imagined.
dave/Kingston
dave/Kingston
Many thanks, Dave...that is certainly smaller than I anticipated....expected something larger. Thanks again.
And the large nut underneath is 33 mm. Perhaps you originally meant that one.
dave
I didn't realise there were two nuts...I assumed it would be something similar to the image below...
Phil
Thanks again....looking at this other image I've found it certainly appears to be the larger nut size.
The top nut on my 89 is 36mm. It changed on later models 90/91?
Hi Phil, Realoem parts list shows the difference between early and late bikes but doesn’t state the size:
Many thanks, Gerry....appreciate the info. (y)
