R100GS Para Front Brake
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
Is it possible to get a new brake piston? Or a Pair ??
Real Oem only list seals
I gave Electric monk the one from mine to get him mobile and am just about to build Escargot back up and went to overhaul the calliper? His brake piston was and still is cracked :eek:
Why not put the 4pot caliper on or do you want to keep the original caliper?
I was thinking more the 4 pot k caliper, just need to take a couple of mm off each mounting lug.
The porsche boxster uses a 40mm Brembo piston on the front brakes. I've no idea if it's the same length piston though. Might be worth a phone call to your local supplier http://porschecalipers.co.uk/produkty/36/caliper_repair_kit_40mm.html
We're assuming you have got a 40mm piston fitted?
I recently rode a g/s with a 6 pot billet and it was a lot better than a 4 pot brembo I had on my pd.
Lighter bike though, but I was surprised.
Damn but they are a work of art aren't they?
Looks cost effective
1296202 SEAL REBUILD KIT for 31mm Pist BIG-6 CALIPERS (12116S) x6 SEALS, x2 BRIDGE O-RINGS 13.45
:aidan
NIce try Boxabits but pistons are 48 mm
:tears
I've a box of F08 s and reconditioned the one in escargots box only realising when I ofered it up to find it was wrong :blast
Pretty sure that they are F08's (38mm) & that rebuild kits are stocked at Bevel Heaven. :D You'd need to be sure prior to ordering though. I sold mine a while ago, otherwise I'd measure the pistons up.
If you can make one of those 4 pot K series ones fit the paralever you can have L'Escargots original one back....:augie
I used a K1100 4 pot caliper and machined the lugs down by 4.5mm. It is better than the original but not a massive increase which suits me as, with a knobbly or TKC front tyre, I've had it lock up lots of times even with the original caliper.
I have a 6 pot x 27mm Toxico on my GS and it isnt much better than the two pot 48 Brembo.
Only advantage is that there is a better choice of pads, and possibly a better wipe pattern, but even with EBC HH pads it is only marginally better than the Brembo with stock pads, and if I could have found HH pads for the Brembo it would be better.
