I know I know its not a mud plugger but its a start.
Not far to go now and the clean-up is finished and out on the road she'll go.
But before I go any further I'm on the scrounge for a pin, It's the pin that goes through the rear master cyclinder lever with the washer and c-clip either side of the rubber boot.
If all else fails I can use a bolt but would prefer the correct pin, their not advertised as procurable because they want to sell the complete master cyclinder for £80 which includes the pin.
The pin is about 30 mm long by 6 mm diameter with a C-clip recess either end.
The original pin was totally seized so had to be drilled out.
. I'm not a very experienced turner (yet) so it will probably take me a while to sort myself out.
