RID is rider information display
Its fuse 3
fuel pump is fuse 6, so if you hear the pump starting and running? Then you are 100 percent sure that the fuse is good because you can hear it
So pop fuse 3 into fuse 6 place and vice versa and ??
I have come across micro-fractures in fuses before
Also notice there are two options for turn signals and hazards
I can;t remember which colour it is at the RID now but there is a permanent live for the time to show
And there is an ignition live to wake up the chip
So either of those or a broken earth wire (plain brown) could be the cause
