Right then I am after Ideas as to what is wrong.
R1100GS, 1999, just had the tank off and the back sub frame off, and replaced the clutch and clutch actuation parts.
I put it back together and it ran, drove to work (11 miles) and it was fine all be it the tick over was a bit high, went to come home and got about 2 miles before it stops.
Now the bike fires and reves without difficulty, however as soon as I put it in gear and try and pull away it just dies, almost like you are running out of fuel which is what I thought it might be to start with - it wasn't.
I have checked the fuel pipes, there is a full tank, both throttle cables are seated correctly.
I am looking for any advice as to where to look next? all suggestions gratefully received, even the piss taking ones as I have run out of ideas at the moment.
...so perhaps check all the connections you disturbed.
