My two 1150s have engaged first gear best from neutral if you pull the clutch in at the same moment you prod down on the gear lever. If I pull the clutch in and then try to prod down into first then fairly often it doesn't want to go in.
As far as I know - it's normal but took a bit of getting used to. I've learned to automatically engage first as per the above and it goes in 100%.
