(RIP) Bin Ridin
Hi,
My '04 R12GS starter seems to take a second to disengage when starting from cold, making a slightly nasty noise. Warm starting - no problem. Actual starting is fine.
Took starter off, cleaned and sprayed a drop of wd40 on the shaft under the pinion, was ok for a short while but noise soon came back.
What is the best lubricant to use which will not get flung off into clutch and which will not get filled with crap? Or does it have to be left clean and dry?
Bin
Bin
