R65 engine failure
Paradiso
Guisborough, England
What do you suppose has happened here? Maybe cylinder studs pulled out? It's for sale on Ebay.
Item 364108563640
Sent from my SM-G925F using Tapatalk
has this had a crash?!
yeah, I suspect it might have....
First clue, cylinder head is a lot further back than it should be (I've sketched roughly where it should be(
Secondly, that bit of rubber pipe linking the airbag to the carb looks a tiny bit squashed....:blast
Saw a similar one in the Alps a few years ago , he clipped the front end of a car during a stupid overtake
Decent money in the heads and transmission. Shame one of the stubs is ripped off.
look again , the barrel is broken at the bottom , and a crack from the 2 o'clock stud going diagonally upwards .
if in doubt , look at ht wire , plug cap rubber , just above , there seems to be a bit of the barrel.
Given that the engine was probably running when the r/h conrod got banana-ed, I wouldn't hold out much hope for the crankshaft either.
I wonder what that kind of catastrophic engine stop does to the entire transmission line?
Whatever the zorst is made from / formed, I'd be using that as a crash bar ... ;)
not moved an inch lol
didnt say the barrels were good!
The block is definitely cracked in the other pics. There isn't going to be much salvageable there. I wonder how the rider faired? He might have gotten away with it if he parted company and ended up in a field. I hope so.
Looking at the crash bar and the cylinder I reckon there’s 2 dents in the back of the tank :tears
New message from: hillsmotorbikes (58,816PURPLE_SHOOTING_STAR Star)
hi , listing is for damaged engine .
TITLE - 1984 BMW R65 ENGINE SPARES REPAIRS
DESCRIPTION - Additional Information:
1984 BMW R65 ENGINE SPARES REPAIRS DAMAGED RH ENGINE / CYLINDER 28080 MILES , INCLUDES TRANSMISSION , SEE ALL IMAGES.
thanks
listing is for engine/g-box only , as i read it.
Thread drift but this one was pretty impressive,
No tossers were seriously injured.
I recall seeing an Airhead on the road from the circuit to the supermarket at the Bol D'Or in 1981 - he'd run wide and completely removed a cylinder (sorry no pics!). They were just loading it into a van to get back to the UK (luckily he'd found someone to do that - imagine the hassle otherwise).
The only public road I've seen with marshals, straw bales, flags etc..... (TT doesn't count 'cos the public can't ride on it).
