Diode Board fitted non - starter
Got a new diode board from
motorworks yesterday and fitted it this morning.
Old diode board with some broken connectors on the left hand side and burnt through in the middle
The new one below it for comparison - it is the heavier duty type which was £3 more
Now correct me if I am wrong but I bought these dampers to fit it on but not sure if it is actually needed on this model as there was nothing on it before
With the old diode board if I connected the battery the battery light would come on with or without the ignition in ON position
It did fire up the other night no problem with the broken diode board as well.
Now when connect the battery after putting everything back together there is no click on the starter motor at all and the battery light does not come on.
Fuses are fine
Battery is charged
I have triple checked the wires are connected to the related connections as they are marked on the board and on the bike.
What am I missing here
I have checked and there is power on the main positive to the diode board and it seems to be earthed properly without the two additional brown wires touching the motor anywhere.
My initial thoughts would be why is the battery light not coming on and why is there nothing on the starter button. The headlight and taillight does work when I switch it on.
