solidstate100 Registered user Joined Oct 19, 2008 Messages 3,843 Reaction score 581 Location ...... Jul 15, 2025 #21 The only things left (if everything you say you have done has been done correctly) would be master cylinder or ABS pump fault, perhaps. My money would be on a master cylinder fault.
motormount Registered user Joined Mar 31, 2025 Messages 18 Reaction score 0 Location Athens, Greece Jul 16, 2025 #22 Thank you, We've changed the master cylinder piston. Could it be that the master cylinder ''champer'' is ''corrupted''? We'll bypass the abs now. If the problem will be solved then it is ABS fault. If the problem persist i should order a new master cylinder. It's very frustrating not being able to locate what's causing the problem in the first place.
