Ratchet Straps vs. Heated Seats?
sven
Haworth, Yorkshire
I usually secure my bike on the ferry with a ratchet strap over the seat. However, I suspect now I've got an RT with a heated seat, this may not be a wise idea - I assume there's a risk of damaging the heating elements?
Ferrys
Put it on the side stand, and go to the Bar. If you require ratchet straps, ropes, tie downs, Fecking boats upside down!
:beer::beer::beer::beer::beer::beer:
Just be sure to use a foam pad (all the boats have them now) across the seat under the strap. It will no more weight on your seat than a lardy arse - that they were built to cosset!
I've had this concern, particuarly when no foam padding about.
Mines survived a few tie downs without foam, I have bunged my spare gloves under the strap before to limit the pressure point.
If there's a newspaper about that could be used folded up a little to spread the load a little.
\v/
