Rear hub hole
Wierpig
merseyside
Just bought a 95 R100R. The rear wheel bolts / hub were covered with a chrome plate.Ive removed it but it leaves a threaded ( about 14mm) hole in the middle of the hub.
Is this standard and does anything belong in here? Im buying a rubber plug for the hole but cant see anything else on tje parts diagram...cheers :nenau
Whats zebede for? I thought it was just to stop the tin plate rattle and removed it.
Is the plate with the threaded hole behind the rubber bung standard or is it part of the chrome cover mounting kit?
here you go
Thank you. Is the boss in the middle of the second picture threaded?
I don't think so; to check I'd have to do work on my bike (no spare final drive on the shelf). You might be able to have a look on your bike instead (mine's a GS anyway, although the parts have same number).
Yes! Thanks for the photos. If you remove the rubber plug marked 110 on the brake shoe side, is that hole threaded?
Ok, thanks for the replies. Looks like mines got some extra pig iron...
