rear light
  • Thread starter Thread starter tonys
tonys
Been fiddling with the rear light on my 03 model, ABSIII GS, as a result, I've ended up with the warning light permanently on (the one that teel you that the rear light filament has failed and that the brake light filament has taken over. Everything is connected right, both filaments are OK and lighting up in the proper sequence, What have I done? Any ideas as to a solution? I notice the manual mentions having the ignition off when changing bulbs, I may have taken the bulb out and back in again with the ignition on, perhaps this has caused a permanent fault reading? Worth diconnecting the battery to clear it? Straws, clutching at!
