REAR LIGHTS TT
GAGARIN
corfu,Greece
Hi everybody and happy new year ....................
have anybody fit to 1150 GS ADV the touratech rear twin lights ?
are they better or ?
any problems with installation?
Yep, easy to fit, look great, much brighter, robust:thumb
Any more words would be surplus....
One of the stupidest things on the GS's... a single filament single bulb rear light on a buzzy twin...
Looks good and also another +1 for the LED "bulb" in the orig holder. I have used one for a few years and even though some of the LED's have died, the light is still better than orig...
I did consider them. But in the end went with my head (not heart) and stuck with the original holder... replaced the bulb with an LED panel plus outrigger panels that extend the brake/stop lights into the indicators. why have two bulbs when you can have 48!!
http://www.ukgser.com/forums/showpost.php?p=1393833&postcount=1
An alternative is to use the TT light which does look much better than standard then fit these LED stop and tail bulbs which gives you 72 bulbs
:dabone and with better peripheral visibility:dabone
:D
http://cgi.ebay.co.uk/36-led-white-...72?pt=UK_Motorcycle_Parts&hash=item230cee8d38
.............so FAILED i bought the led bulbs but ,....first the led bulbs are good but the the bike read lower watt and light the siglal bulb front under the ABS light............second the holes of the two screws at each light was litlle broken and they broke total when i tried to put it on the bike , have done a reserce for the part but the have news 70-80 € very expensive when all the system have 110, so the solution is the rutern at the OEM part :(
