Planning to remove rear pads as at 5,500 they look very near the metal. How do I remove the pads, it looks a bit different to the old hex head RT I swapped for the GS?
Is it as simple as removing the 2 spring pin clips, knocking out the pin and pulling out the pads or do I need to remove the caliphs first?
I just want to check there is enough material to last another 1000 miles when it's due for a service and I'm expecting the dealer to replace the pads under warranty. I've no idea what is causing the rapid wear but it's unlikely to be my riding style as it's not changed and the rear pads on my previous GS and RT didn't need replacing until about 20,000
