Recommend me a C spanner
Posh Pete
Still got a pulse.
Embra, Scotland
About to do some work on the R100GS front forks. On earlier airheads, fork tubes used to be secured by a large hex nut. Not on the GS which uses a notched nut requiring a C spanner. Naturally, the one in the tool kit does not fit! :blast
So I need a robust C spanner of the right size. Any suggestions?
Perhaps a pic would help. The top of my fork tubes (1992) are a large hex nut.
Motoworks have a 'pin spanner', half way down this page. Is this what you are talking about perhaps?
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=20&Ct=ZA&SbCt=BA_15_20_ZA_50
Ta. The pins are for the 'oles in the fork top cover on earlier bikes. Metal and chrome: proper quality back then! The later bikes use plastic squeeze on caps. The hook end is a bit slim for the recesses on my stanchion cap.
Part 4 in the diagram
http://www.realoem.com/bmw/enUS/showparts?id=0478-USA-10-1988-47E1-BMW-R_100_GS&diagId=31_0373
The actual part is notched 4 ways for a C spanner. This is not shown on the diagram.
The realoem site is getting to be a real pita for ads btw!
Peter,
Are you sure you're not referring to the steering stem top nut - mine requires a 'C' spanner.
Your 100 GS is the same year as mine and mine has hex threaded caps on the stanchions.
Bob (confused).
Peter,
Bob (confused).
Curiouser and curiouser! I'll take a pic Bob.
Voila! That's a 13 mm box sat in the hex cavity. The BMW oem site diagram suggests that the whole cap is a unit but I'm wondering if the outer part acts as a locknut for the inner bit that retains the spring?
Well spotted that man! Cheers Gordon. Question now is whether to plough some more cash into those hyper pro springs! :D
Edit: maybe the thread pointed out by Gordon could be made into a sticky? Or moved into the "Common faults etc" sticky section?
Are you sure you're not referring to the steering stem top nut - mine requires a 'C' spanner. Bob (confused).
Peter,
Ignore me - my memory is worse than I thought. I had a look at my 100 GS today and its the same as yours DOH :blast.
Bob.
It doesn't come itsel' Bob. Part of the reason for the pic was to reassure myself about what I thought the layout was!
Check the site carefully, at one time they had the springs for the HPN inserts which work well with a 450 lb spring on the rear shock, 90mm preload spacer and stock quantity of15 /5 wt fluid in R/C.
Helps if the rear spring is in an Ohlins too!
Never fitted Hyperpro's own set up to an Airhead, but a very expensive set for a VFR made the bike almost unridable on the road, with rider sag less than half of what worked.
Im with beemerbof on this one - I fitted a set of Hyperpro's to my G/S and the spring rate was WAY to high - probably OK if you weigh about 50 stone and have your Paris Dakar tank full 100% of the time, otherwise extremely unpleasant to ride on.
