Remote oil filter
Ianak
Dorset
I have the standard remote oil filter on my Norton and the same on a Triumph does anyone know of a smaller size filter that will fit the thread on the remote filter housing or is there an alternative remote filter set up available please or maybe I could maybe make a bush to suit the BMW 1200 filter which is a slightly smaller size
Morgo is the smallest available. Thunder engineering make works of art and may have something you could use.
This is to fit to Brit classics I just checked the Morgo looks the same size as the one used on the Norton which is a bit too big to hide on an Ariel VH 500
the Unique looks like a compact option but a bit pricy for what it is I can buy the filters for £5.95 and I can make the filter housing very similar to the Unique design I have 2 Royal Enfields so probably get 1/2 a dozen filters at that price
thank you chaps
Ive fitted four morgo filters on different makes of brit bikes. Are you assuming the filter bodies are the same as a car filter? They are much smaller.
the Morgo says 21/4 diameter but I can make it a smaller diameter using the Enfield type element they are £81 each plus vat and postage I need 3 so I think I will make them from steel stock I already have and use the Enfield elements easy to make 3 at same time
