Good thread mate spoiled by know it alls. No problem on the motorway or overtaking to use the indicator but coming up to a junction with using the clutch and have to indicate gives the left hand a good workout. But now I'm used to it I don't knock the wheel anymore. However I found that the position of the indicator is too high up for a natural thumb movement which causes the grief with the wheel. Swap the indicator and horn around and it should be sound. Thanks for posting such a detailed description.
Regarding the wheel rotation I reckon there is a reference signal so that it can determine the zoom in or zoom out signal.
The future is whatever colour you want.
Thanks Tanneman (and I like your avatar pic!). I've come to expect some negativity/abuse here, though it's only a minority. Doesn't bother me, and IMO just reflects badly on those who post like that - but they don't seem to see that.
Regarding the rotation sensing, that's an interesting one. There is a circuit board inside the wheel with what appears to be two sensors on it (could be Hall effect). Inside the outer rotating part of the wheel there is a thin circular ring. I believe this is some sort of reluctor ring, almost certainly magnetic. Reluctor rings are the things used to help sense rotation - most common examples being the slotted ABS disks on bikes, and the toothed rings on many car ABS systems. However, I have read that magnetic types are also used, with these being manufactured to have alternate North and South magnetic poles built into the material. I'm not sure of exactly how this would work in the BMW wheel, but I'm pretty sure the end result is a signal showing that rotation of the jog wheel has occurred, and what direction it is in.
I am hoping that the output is the equivalent of one switch closing then re-opening for each downward jog, and a different switch doing the same for each upward jog. It seems that way because rotation of the wheel seems to trigger discrete steps in the zoom in/out on the satnav, rather than a continuous change. The left and right sideways jogs are just sensed by microswitches closing, just like all the other switches in the switch cluster, so if the up and down rotations get processed into a similar switch type output then I should be able to emulate the wheel with a simple and much smaller four way joystick or navipad device.
The problem will be if the rotation is encoded into a LIN bus signal within the wheel itself, as I would not be able to emulate that. However, I think all the other switches in the LH cluster feed into some electronic circuitry encapsulated into a recess in the base of the switch cluster, and the connector for the wheel also feeds into that space, so I hope the wheel output is not encoded, and only gets encoded on to the LIN bus, along with all the other switch inputs, in this switch cluster circuitry.
I hope to hook up a spare wheel to the bike and test this theory once I receive the secondhand wheel I have ordered. It will involve some dismantling of the wheel, and possibly cutting and extending the wires on its connector, so I don't want to do this with the original wheel.
Fred
