remus with panniers on 1200
shedracer
Dorset.
Right guys, those running the Remus pipe, do you have the BM panniers and if so do you use the Remus deflector? While enquiring about the can, I was told you need the deflector when using the panniers.
Is it nesessory or can you ride with no additional heat deflectors?
Whats your experience?
Paul
Hi
I do not use the deflector. If you notice the part # -- it was designed for the 1150 and the panniers had no heat shield on the 1150.
The Remus can melt a plastic rear # plate though. I had to replace with metal.
Quentin
The above is an opinion -- pls don't blame me if you melt your cases!
Heat Deflector
No you dont have to buy the remus heat deflector. I have been running a full remus system on mine for the last 2k miles without any damage (including number plate)
The GS1200 Panniers from BMW now come with a heat shield already fitted so you needn't bother.
